-1
How many times, in general, can I apply the windscreen washing fluid until it's empty? If the car has applications to both the front windscreen & back window, how does it count? Are those two separate containers or one container with two pipes?
If the answer varies greatly between models, my car is a Nissan Note.
closed as too broad by Zaid, Pᴀᴜʟsᴛᴇʀ2 Jun 3 '18 at 11:57
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • Of course it depends on container size, which windows you spray and how long you spray each time. NOFI but was that really too hard to think of yourself? – MadMarky Jun 4 '18 at 9:15
  • @MadMarky I thought there may be like a standard container size or nozzle application that is used on most cars. – kevin Jun 4 '18 at 16:08
Depends on:
1) how long you spray the washer fluid for... And
2) some cars have separate bottles but most newer ones have only one : less for the owner to think about
3) some cars also have headlamp washers which also use that supply, usually only when the headlights are on though,
So, the answer is it depends...
  • For (1) is there a time limit? Like it takes 60 seconds to empty the bottle, then I can divide that by the duration of each application to get the answer. – kevin Jun 3 '18 at 11:06
  • Also, my 2016 RAV4 uses the headlamp washer only for the first, sixth, eleventh, sixteenth, and so on times the windscreen washer is operated. So, on a long drive, only one fifth of the windscreen washer applications results in a headlamp wash. – juhist Jun 3 '18 at 11:18
  • @juhist there are probably as many plans as manufacturers... – Solar Mike Jun 3 '18 at 11:32
  • @kevin well, I have on one car in the past had to run the pump to empty out the reservoir and it did not stop... however, some cars may put a limit... – Solar Mike Jun 3 '18 at 11:33
