Mechanic changed air filter and crank sensor, to no avail. He says further tests might be quite costy. Any suggestion as to what could cause this problem?
Codes: P1336 (crank sensor) and also P0204 (injector)
  • Did he read the codes before doing anything? Has he checked for air leaks?
    Jun 2 '18 at 14:59
  • I just collected the car, mechanic gave me the code I added to my question
    – drake035
    Jun 2 '18 at 17:52
  • So the codes have just been read ? If do, then either they have not been cleared or the crank sensor or wiring is still defective...
    Jun 2 '18 at 17:58
  • The engine autodiagnosis system lamp went off after a few days without me doing anything. First the car stopped stalling while idling when car was cold. Then it stopped stalling altogether with the warning lamp now off. I suppose this should narrow down the problem a little bit as to the probable cause?
    – drake035
    Jun 7 '18 at 10:05
  • Correction, it does it again. Very capricious issue it seems.
    – drake035
    Jun 8 '18 at 18:09
