My explorer has what sounds like implosions or miss fire's in the intake when taking off and wants to stall and will stall when I come to a stop can anyone help. Some times runs rough some times runs very good.
1Welcome to Motor Vehicle Maintenance & Repair! Do you have a check engine light on? If so, have you read the codes? – Pᴀᴜʟsᴛᴇʀ2♦ May 31 '18 at 11:19
Two things I would start checking : has the timing slipped? and do you have an air leak? – Solar Mike May 31 '18 at 13:53
1Are there any OB2 codes in the computer? – Moab May 31 '18 at 19:41
sounds like the cam position sensor..the unit.. not just the cap...its a problem ford has had for some time...i just replaced one on my 2001 explorer...same problem as you have...bushings wear out
Thank you it was the camshaft synchronizer and sensor it broke in side the cap. – Tim Jun 2 '18 at 23:06
