I'm looking for the PCV valve in my Peugeot 106 1.1 TU1JP (HFX) year 2000.
I can't find it, the closest thing I found is a hose going from the cam cover to the air filter, the connector on the air filter goes to a simple thin rubber diaphragm facing inside the air filter case. Is this some kind of PCV?
thanks
  • That is the other half of the PCV system, fresh air intake.
    – Moab
    May 29, 2018 at 16:34
  • where should i look? Been looking like a week already :)
    – Rhinoted
    May 29, 2018 at 18:52
  • Probably in the valve cover or close to it.
    – Moab
    May 29, 2018 at 20:35
