2009 Journey has coolant on floor of garage on passenger side. Car doesn’t overheat but had to add coolant to the reservoir. Mechanic can’t find leak.
  • Welcome to Motor Vehicle Maintenance & Repair! Is it actually a coolant leak or is it just moisture leaking onto the floor? May 27, 2018 at 15:52
    If it is coolant your heater core is leaking and needs replaced, if it clear water then the drain for your AC box is clogged.
    – Moab
    May 27, 2018 at 16:32
  • @user37934 - I see you now have a regular account and appreciate the edit. If you'd like to take ownership of this question, please have your accounts merged by following the directions at this link. May 27, 2018 at 21:34
  • Taste it , glyco will be sweet ( don't swallow ) . If not sweet ,it is water condensate. Yes , I have done it a few times and never died. Aug 29, 2018 at 20:04
If its really coolant, then heater core is probably leaking. Surprised your mechanic can't find that.
If its just water (even dirty water), there should be a drain (if you've ever seen a car drip water on a hot day with the AC on) have your mechanic verify the drain is clear.
Both are typically on passenger side of car.
