Sometimes my horn works sometimes it doesn't. This has been going on for a few months now.
Is this an easy diy fix? What might the cause be, what things should I look into?
If I have to open up the steering wheel, is there anything I need to be aware of like air bag being released, I think I read somewhere that might happen if you open the steering wheel.
Thanks
  • It depends on the car and how the horn functions. It should function through a relay. If it is working intermittently, then the wiring should be okay, but isn't a given. You have the horn button, relay, power, or ground connections which might be at fault. You can check the horn directly by attaching a 12vdc source directly to it. I'd start checking at the horn and work your way back, ensuring everything is golden as you go. – Pᴀᴜʟsᴛᴇʀ2 May 26 '18 at 2:02
  • @Pᴀᴜʟsᴛᴇʀ2 The electrician's lament : whichever end you start , the fault is at the other end... :) – Solar Mike May 26 '18 at 7:34
