My 2009 Honda Accord engine light starts blinking every time I turn it on and then after min the VSA and triangle with ! Comes on. I changed the crankshaft sensor but the problem is still there. Anyone else having this problem? Any help will be greatly appreciated.
  • Did you use an aftermarket sensor? Try one from the dealership. – Moab May 25 at 19:29
  • How many miles? you need to verify it's not a valve clearance issue or an ignition/mechanical misfire first. There's also a TSB concerning voltage drop on cranking. If all that checks out do a cam crank relearn with the appropriate scan tool. – Ben May 25 at 20:54
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
