I have a Hyundai Tucson 2005. Bought it recently. The AC gives cold air for some time (like 20-30 min) and then blows hot air. If I turn it off and turn on again, it will still give hot air. It may again give cold air after I turn if on after a long time. The Freon level is okay. What can be the problem and how do I troubleshoot it?
10
  • Is the condenser blocked? – Solar Mike May 23 '18 at 15:21
  • Look for the compressor's clutch plate in front of the pulley (yours is a Denso btw, either the 10PA15C or the 10PA17C, pictures on the net don't show any thermal switch on its body). When you begin to feel the air becoming warm, check if it's still rotating (cycling, i.e. rotating for a certain time and then stopping for a certain time, then resuming rotation and so on, actually) or it has suddenly become completely stationary and won't rotate anymore. – Al_ May 23 '18 at 17:36
  • Another thing worth mentioning. Check if the "hot air" also comes with a noticeable reduction in vent airflow vs "cold air". – Al_ May 23 '18 at 17:53
    How did you check to ensure the refrigerant is at the proper level? This is strange ... if there's one thing which always seems to work on a Hyundai, it's the AC! :o) – Pᴀᴜʟsᴛᴇʀ2 May 23 '18 at 18:03
  • The only way of knowing if an ac system's refrigerant is at the proper level is evacuating the system and weighing what's been evacuated. Has this been done? – Al_ May 23 '18 at 19:37
