I have a 2008 Honda Fit and in the manual says "Honda doesn't recommend using synthetic oil".
I want to know why, as I can't find the answer online. Seems like any car can use synthetic, why mine says it shouldn't?
I'm using a semi synthetic by Shell as recommended by my mechanic, but I think I will switch to mineral by Honda next change.
  • WE DON'T RECOMMEND synthetic oil for use in our engines. DO NOT USE synthetic oils in our engines. These 2 statements above mean different things.
    – Gus
    Jul 29, 2019 at 15:36
That statement "usually" means that they have not chosen a preferred supplier...
I used a top quality fully synthetic oil in a diesel that had a turbo added and it was fine, the engine, did not have a synthetic specified either, especially as it came from a Nissan and was fitted into a Volvo...
If the synthetic matches , or exceeds, the specifications for the engine then it should be fine.
    The last sentence says it all. If the oil meets or exceeds the API service and Group specifications from the manufacturer you should be OK. I have no idea why they would recommend dino oil exclusively.
    – Tim Nevins
    May 23, 2018 at 16:29
