I'm planning to replace my rocker cover gaskets and spark plug seals on my 2007 Subaru Outback, as there is a slight oil leak onto the spark plugs.
I've also purchased some ThreeBond 1207B gasket sealer to help with the task.
However the product didn't come with any instructions on how to use it so I'm a bit unsure.
What is the best way to use ThreeBond 1207B when replacing rocker cover gaskets and spark plug seals?
10
  • Check threebond 1207B on the manufacturer’s website.
    May 23, 2018 at 8:10
  • I checked website, no info on application....threebond.com.au/liquid-gaskets.html
    – Moab
    May 23, 2018 at 20:11
  • Most rocker cover gaskets are rubber and require so sealants.
    – Moab
    May 23, 2018 at 20:12
  • @Moab that seems to be the Australian distributor...
    May 23, 2018 at 20:29
  • They are the manufacturer.
    – Moab
    May 23, 2018 at 20:44
Here is a link to the instructions and an image of the most relevant part:
  • Good point and well spotted - saves having to do the job twice...
    May 23, 2018 at 21:38
