got a slight cut in the sidewall of the tyre. What do you recommend - repair or replace? Its a fairly new tyre with just ard 11K kms done. Pls suggest. Thanks! enter image description here
  • There are dozens of answers on this stack covering this exact topic, so I am voting to close this. A summary answer, replace the tire if you have any question about the type's safety. – kyle_engineer May 21 '18 at 20:58
    Possible duplicate of Tire SideWall Damage. Replace? – kyle_engineer May 21 '18 at 20:58
    Every question on this topic is different and requires a picture to get a safe opinion or answer, so they are not duplicates technically. There should just be a wiki for this type of question, with general advice about any tire damage. – Moab May 21 '18 at 23:00
  • Relying on a wiki, as advised above, is not the safest course of action - replacing the damaged tire as per @kyle_engineer is a safe course of action, or taking it to a professional tire fitter / establishment for inspection and subsequent action is also safe. – Solar Mike May 22 '18 at 5:45
  • 3
    A picture doesn't really do it. That looks very minor to me, but what I am willing to drive on and what I recommend to my customers are entirely different things. The topic simply has too much liability to make a "looks purty okays to me" kind of suggestion. I've seen huge chunks missing which I know are okay to drive on. I've seen tiny slits that look fairly innocent, but hide a huge deep cut that has cut through sidewall bands making the tire unsafe. "Whadya think about this??" Replace it. – SteveRacer May 22 '18 at 6:04
Is it leaking? If not, leave it. If it’s leaking, never repair a sidewall. You’ll be at risk of a blowout. Buy a new tire and be safe.
| improve this answer | |
  • Hello Alex, thanks for your reply! It doesn't seem to be leaking. I do plan to show it in the workshop to double-confirm. – Aditya Gaurav May 28 '18 at 4:01
  • pretty accurate answer. It's illegal to repair sidewalls. – John Lord Jul 26 '18 at 5:24
