It's not broken, I'm only interested how it works. Pressing the clutch is not needed to operate this handle. It can also take a few seconds before it starts moving. The red handle
  • Welcome to Motor Vehicle Maintenance & Repair! May 21, 2018 at 17:18
  • 2nd comment - it's basically an auto box...
    May 21, 2018 at 20:34
  • Not sure, but it has manual gears and in some gears pulling the handle backwards will make it go faster. (look at the little arrows)
    – MatMis
    May 21, 2018 at 21:27
  • Could it by a hydraulic drive?
    – SteveRacer
    May 22, 2018 at 6:43
  • I don't think so because it feels like you would be able to stall the engine if you start it in a gear that's to high.
    – MatMis
    May 22, 2018 at 20:06
The International I drove had a clutchless change between 1-2 then 3-4 and 5-6 , this was done with electro-hydraulic clutch packs.
When they changed the clutch they put the low p sensor wire on the high sensor and vice versa - took a while to sort that!
