If the AC was leaking and someone unhooked the AC unit, would that be causing the belt to squeak now?
If so, what would you suggest?
  • Welcome to Motor Vehicle Maintenance & Repair! May 9, 2018 at 21:04
  • What do you mean by leaking and unhooked. In order for us to answer much greater detail must Be given May 10, 2018 at 5:42
  • Definitely give more info, not enough detail to give a reasonable answer.
    – Al_
    May 10, 2018 at 8:57
  • @Peggy How did you unhook the AC? Did you remove a fuse? Discharge the lines? Take out the compressor? Also, are you sure it's the belt squeaking, or are you simply hearing a squeaking noise and are wondering if it might be the belt?
    – Cullub
    May 10, 2018 at 16:26
  • This seems to work: youtube.com/watch?v=_8RE8p_m8bA
    – Ruminator
    May 10, 2018 at 18:19
