I was thinking of buying a car but it ALWAYS grinds when shifting into 4th gear (up or down) regardless of the rpm. It occasionally grinds when shifting into 5th and 6th (only up) at a higher rpm. The owner told me that he just put in a new clutch (did it himself). I did notice that the clutch pedal was stiffer than I am used to.
Is this a result of the new clutch with a bad adjustment, or are the synchros bad? I didn't know about the double clutching test until after I looked at the car. He lives a pretty far drive away to test this again.
Does this have serious repercussions if ignored?
    If you've not bought the car, walk away. A new clutch wouldn't cause this. May 4, 2018 at 2:15
  • I haven't bought the car. Even if it is an expensive repair I would like to know the answers for personal knowledge. The cost of the car was cheap enough where it might still be worth a full transmission rebuild.
    – Mocking
    May 4, 2018 at 2:17
    I'd suggest there's an issue with the transmission (internally), but you won't know until you pull the tranny apart. Be prepared to completely replace the transmission. May 4, 2018 at 2:20
  • You should put your two comments in an answer so I can upvote you. Those answer my questions enough.
    – Mocking
    May 4, 2018 at 2:21
    if the grinding (sound) occurs when the gear is shifted after the clutch is fully depressed (and before re-engaging it) , then it's a sign of worn out synchros.
    – chilljeet
    May 4, 2018 at 17:08
