I have 2007 Chevy Aveo and I need to replace this part but don't know what it is called. It's a "t" square that water runs through one part and air through the other and connects to the throttle body
16
  • Are you certain water runs through this?
    – mike65535
    Apr 30, 2018 at 20:07
    Looks like it is part of the pcv system with a check valve in one direction...
    Apr 30, 2018 at 20:13
  • @SolarMike PCV is in the valve cover, more than likely it is just a tee.
    – Moab
    Apr 30, 2018 at 20:21
  • @Moab a tee has 3 ports, that has 4...
    Apr 30, 2018 at 20:31
  • Or a "cross", 4 vapor hoses ; looks like it may be a check in addition to the PVC. Apr 30, 2018 at 20:33
After doing some research, I think I found your part. See diagram below:
Aveo diagram cam cover
You can see that the little T-junction is part of the PCV hose assembly (item 21 in the diagram). Unfortunately, this means you can't source the part separately, you'd need to buy the whole PCV hose. The part number of the PCV hose is 96474643.
