I have recently bought an Audi a3 2008 TFSI, and had a mechanic checking the engine over before buying it. He had to repair an oil leak and refilled the oil, everything seemed good to him.
Today when I was driving through the hills, the oil pressure warning light appeared on my dashboard. I stopped the car and checked if the oil level was fine. It is definitely not leaking anymore, but I feel like there is too much oil in it.
Please check out the attached image.
There is a slight bend in it, but the arrow indicates the oil lvl.
Is this an exces amount of oil, and could this be causing problems with the oil pressure?
I appreciate the help
