2004 Accord LX cruise control fails intermittently on Hwy after crusing around a half hour. Works again next time I drive in order to fail again after driving a half hour next day. Cruise switch replaced twice remains the same. It has been like this for a few months. Can somebody help?
  • Have you had the codes read? There may be an intermittant fault causing the ecu to cancel cruise. – Solar Mike Apr 12 '18 at 6:57
  • 3
    A possible cause is a defective brake light switch. Have someone follow you and see if your brake lights flicker without you applying the brakes. – mikes Apr 12 '18 at 8:38
  • Welcome to Motor Vehicle Maintenance & Repair! – Pᴀᴜʟsᴛᴇʀ2 Apr 12 '18 at 13:23
    Shift lever or clutch pedal movement or defective switches of these can also cancel cruise on that model. – Moab Apr 12 '18 at 16:47
