I have a 2005 Type-S and can't get the left DRL to work. I'm pretty sure these share the same bulb with the high-beam so it's strange that the high-beam works but the DRL doesn't. I replaced the bulb and checked the fuses but they seem ok (unless DRL has it's own fuse)... The fuse I checked was under the bonnet no.15
Any ideas what else it could be?
1. Under Bonnet Fuse Box
2. Interior Fuse Box
  • there are 2 headlamp fuses, 15 and 17. DRL should be low beams by default.
    – Moab
    Apr 10, 2018 at 15:35
  • looks like you have a bad bulb on the left side.
    – Moab
    Apr 10, 2018 at 15:59
  • The fuse would take out both sides.
    – John Lord
    Jan 5, 2019 at 14:06
I had a problem with my old Civic that the contacts on light bulb socket where corroded, especially on the left side. Check this and clean/replace if necessary.
