My scooter won't start by using the kick start when warm, without help by twisting the throttle-handle a bit (at the same time as using the kick start).
By "warm" I mean it's been stored in a room with a temperature at about 20 degrees (celcius), but not been actively running in at least 7 hours.
When the temperature is 0-10 degrees (celcius) or the engine has been running for some time, it starts just fine without any help.
What causes this? Could it be a defective idle-jet or choke?
My scooter has a 50cc GY6 engine, a CV carburator and a choke.
  • Is there a choke?
    – Moab
    Apr 9, 2018 at 19:53
  • Hard to say without knowing more. What kind of scooter? How old is it? Is the gasoline fresh? When was the last time it was serviced? When it does run, does it run well?
    – CharlieRB
    Apr 9, 2018 at 19:59
  • Question edited - the scooter has a choke.
    – Birdman
    Apr 10, 2018 at 14:41
  • Vapor Lock? How much throttle?
    – NitrusInc
    Apr 10, 2018 at 15:48
