What number should I adjust my Torque Wrench to when I torque a shock absorber?
the repair manual says 98.1 ~ 117.7N.m so should I adjust it to 98 or 117?
I have to change a leaking shock absorber on my hyundai 2015 Accent but I don't know how to adjust my Torque Wrench.
    Go for the average about 110 would do...
    Apr 8, 2018 at 11:11
  • Welcome to Motor Vehicle Maintenance & Repair! Apr 8, 2018 at 12:54
  • Of course, you have had your torque wrench calibrated recently...
    Apr 8, 2018 at 13:15
    I've never seen torque listed as a range. In the manuals I've seen, it's always a single exact figure. Is this common and I'm just not aware of it?
    – JPhi1618
    Apr 9, 2018 at 3:38
As Mike said in the comments, shoot for somewhere in between. Set your torque wrench and forget it. As long as you are hitting a number in between the specifications, your car and shock absorber will be just fine.
