I have read the claim that modern automatic transmissions cut fuel to the engine on downhill stretches, thereby making it more fuel efficient to go down a large hill in drive than in neutral. However, I have found in my own experimentation with a vehicle that shows current fuel consumption (in the form of the instantaneous mpg) that is is not always the case and fuel will actually be injected at certain times when going downhill, apparently when it detects engine drag is slowing the vehicle down too much.
When no fuel is being injected a significant braking drag is acting on the vehicle. When going downhill there is a slight but noticeable lurch when fuel injection begins as this braking drag goes away. While this drag is good for the highway where for example you might easily maintain the speed limit and even need a touch of brakes on long hills, for city driving it can result in a substantial decrease in fuel economy. In an experiment I performed, I found that fuel economy could be improved around 10% by always shifting to neutral for downhill stretches for which this would not result in exceeding the speed limit by more than 5mph. This is not insignificant - if everybody driving in the U.S. increased their fuel economy by this amount it would save close to 40 million gallons of fuel per day. (source) Of course, actual fuel savings probably won't be as large for everybody as it is for me - it seems to help to live in a hilly area or drive a lot of stretches where it's downhill enough to maintain speed coasting but not with the transmission engaged, and it applies mostly to city driving - but it seems like there is still enough savings that it would more than pay for engineering time to developing an improved transmission program.
So I am wondering why automatic transmissions aren't designed to automatically select neutral when it would be more fuel efficient to do so? I don't think concerns about the safety of driving in neutral could be the issue, as since it's under computer control the car can automatically shift back into gear the moment the brake is pressed or the accelerator is pressed enough to overcome what would be engine braking - the car is already smart enough to automatically kill the gas if you enter neutral while cruise control is on, for example. Has nobody thought of this before or just don't care to make it better? Are there serious downsides I am not seeing?
Update: I'm going to do a more formal measurement as soon as I get a chance here. Informally I took a couple of data point on my way home on a downhill stretch started off mild <1% and increased to >6%.
1200 rpm, speed ~35mph, MPG=62
1500-1800 rpm, speed ~40mph, MPG=87
at this point I hit the steep part of the hill and hit the button on the side of the automatic so it would engine break harder
2000 rpm, speed ~48mph, MPG=150 (this is pegged, at this point I believe no fuel is being used)
So this seems to refute the assertion that "When you take your foot off the gas pedal and the engine is ~1500-2500, the ECU will cut fuel completely to the engine." One other data point, if I am coasting and the engine is at idle, I find that MPG is always twice my speed (in MPH) indicating that at idle I am burning 1/2 gallon per hour. So getting 87MPG at 40mph is barely doing better than idle, and going 35mph it is actually worse.
8
  • I don't know much about what happens mechanically when a transmission goes in and out of neutral, but I think that might be as important as any perceived safety issue. Also, here is a related question.
    – JPhi1618
    Commented Apr 6, 2018 at 18:47
  • @JPhi1618 I actually was reading this answer to a slightly different question, which to my reading at least seemed to imply that the mechanical linkage of automatically shifting in and out of neutral would be no different than normal shifting between gears.
    – Michael
    Commented Apr 6, 2018 at 18:52
  • There's also the problem of changing a basic assumption of how a car feels to drive. Everyone expects a car to slow down when you lift off the gas. Even electric cars react this way, so it's a pretty big deal to change such a fundamental behavior - or is that not what you are suggesting? Oh, and the question I linked to was not supposed to be an argument for or agains your question, just related.
    – JPhi1618
    Commented Apr 6, 2018 at 18:53
  • @JPhi1618 I didn't want to imply that, which is why I didn't include it in the question. But after reading it it seemed like there wasn't a mechanical safety issue which prohibited doing it automatically.
    – Michael
    Commented Apr 6, 2018 at 19:14
    I wrote an answer which covers this but cannot find it (GoogleFu is not up to snuff today). Basically, you want to leave it in drive because you'll get better gas mileage. When you take your foot off the gas pedal and the engine is ~1500-2500, the ECU will cut fuel completely to the engine. This is part of the tune to save fuel. If you put it in neutral, the ECU will still have to have fuel going through the injectors to keep the engine running. Commented Apr 6, 2018 at 20:36
Let's for simplicity assume going to neutral does save the same amount of fuel as operating the engine in overrun.
Then it'd still be the wisest to choose to overrun the engine rather then selecting neutral everytime. For the same reason, no freewheel clutch is present in the transmission. A fixed connection between wheels and engine gives the most predictive behaviour, and that's important in a car or any other vehicle. Going to neutral will give slow response when stomping the gas in case of sudden need/demand. It'll have switch to the correct gear if it hasn't already, and it has to synchronise engine and transmission speed. That costs precious seconds and will give a sluggish and unsafe feeling. It'll also put more strain on the transmission.
