Please if some one can help me. Recently I discovered that no pressure arises from the pump, I wanted to check the fuse or the relay but I couldn't recognize it. Here is a photo of the external fuse box in my car.
This is the internal fuse diagram photo:
  • I don’t remember there being a dedicated fuel pump fuse on these older toyotas usually they iirc used the circuit cut relay and maybe the am2 fuse. As part of a larger circuit. – Ben Apr 2 '18 at 17:51
  • If you are worried about it being a fuse but cannot find one which is exactly for it ... check all of them ... and the relays as well. – Pᴀᴜʟsᴛᴇʀ2 Apr 2 '18 at 22:21
  • Its actually called the circuit opening relay and it pulls power from the efi relay and fuse on usdm toyotas. – Ben Apr 3 '18 at 3:39
