03 Saturn replaced engine but when trying to start nothing happens. I have power to all the lights and gauges but when trying to turn the engine over it does nothing no sound or anything.
Also I had cut the white wire for the passlock fee years ago so I thought maybe I had to connect that again I did but it still did nothing.
Any help is appreciated
  • Can you jump the starter relay to make the engine crank? Any codes? – Ben Apr 2 '18 at 20:37
  • When I jump the solenoid the starter spun and not sure about codes the scanner doesn't power on when I plug it in – Chad Apr 2 '18 at 21:13
  • Check your fuses theres either a dedicated dlc fuse or its powered off the power outlet fuse. Make sure the dlc has ground as well its one of the middle pins. – Ben Apr 2 '18 at 21:15
  • I will check that hopefully within the next couple days since car isn't at my house I can't go eight out and check but thanks for the advice – Chad Apr 2 '18 at 22:55
