So the question I have is are there any major benefits to the oil-less turbo technology that exists today? What makes a turbo like this better from a traditional oiled turbo? (Not specific to any car however)
  • I would assume oil-less bearings have less rolling resistance, so faster spin up times.
    – Moab
    Apr 4, 2018 at 22:15
-2
Oil-less turbo's are a idea. COMP Turbos inc. i believe are the only company producing them.
So Oil-Less turbo Benefits!
  • Don't have to run an oil pressurized line to lubricate the turbos bearing.
  • Don't have to worry about exhaust heating that line.
  • Don't have to put inline oil filter and or replace.
  • Don't have to worry about angle placement of the turbo.
  • Don't have to run return oil line. enter image description here
You can run COMP's oil-less turbos anywhere they fit: Rear, Top, Side, Under, Over and in at any angle you'd like!
Only draw back is you have routine greasing with COMP's special grease.
It's really a no brainier! good luck.
    I'm going to have to downvote this because it's an advertisement. Remove the vendor-specific references and I'll reconsider.
    – 3Dave
    May 2, 2018 at 20:54
