My scooter has run 7600 km and after a service 3 days ago it now stops while riding. I have had it stop in the middle of the road.
It is very difficult to then self start it.
What could be the problem here?
  • Yes..three days ago
    – karina
    Mar 28, 2018 at 8:59
  • Did this only start after the service three days ago? Mar 28, 2018 at 9:03
  • Yes ...they say everything is ok..but during ride its a problem
    – karina
    Mar 28, 2018 at 9:05
  • what kind of motor has it, carburated 4-stroke?
    – Daniel
    Mar 28, 2018 at 9:08
    Take it back to the place that did the service. Mar 28, 2018 at 9:54
Take it back to your shop and have them fix it.
Has probably something to do with the carburetor setting or the fuel-supply to it. Presumably they did work on it during service?
  • Does it have anything to do with spark plug?
    – karina
    Mar 28, 2018 at 13:07
  • Could also be, was work done on the spark plugs? If there is a loose connection the sparks may be insufficient to secure ignition ...
    – Daniel
    Mar 28, 2018 at 13:30
If your scooter is provided with one, have the depression fuel tap and line checked.
  • What is a "depression fuel tap"? Are you referring to the choke?
    – Zaid
    Mar 29, 2018 at 6:30
  • Sorry, not sure what is the exact name. Maybe the "petcock"? Some scooters have the fuel line blocked unless the engine is running. Usually there are 2 tubes from the carburetor to the fuel tank. One is for fuel and one is for the depression which "switches the petcock on"
    – fededevi
    Mar 29, 2018 at 9:30
  • Hello...Yesterday my scooter was serviced and after 15km of its ride..it stooped...then I called the mechanic and we found out that he forgot to put the engine oil...so.after refilling the oil..the scooter is working.but I want to knw.m,whether thos will create some problems in the future or not?
    – karina
    Apr 22, 2018 at 5:39
