I have heard of the 'cable cut' principle for immobilisers but have also heard that this can be detected by car thieves with equipment. Does anyone know what this is?
I am looking at this immobiliser for my car but not sure if "cuts" cables?
https://www.pandoracaralarm.com/catalog/accessories/blockage-radio-relays/pandora-rr-101.html
Thanks
  • It’s you who cuts the cables when fitting.
    Mar 27, 2018 at 4:11
  • @SolarMike - I believe the OP is asking about the type of alarm, whether it requires the installer to cut the cables or if it installs inline (using factory connections) to install without having to hack on the wiring harness, not who does the cutting. Mar 27, 2018 at 10:20
  • The provided link looks to be a solid state relay thats part of a larger system. So if by “cut” you mean the circuit is open by default, than yes.
    – Ben
    Mar 27, 2018 at 11:35
