I have Volvo 850 and the heater core is leaking... again. The same thing happened 3 or 4 years ago.
Is there some design issue that is causing this to happen repeatedly? If so, any long-term fix?
  • Possibly electrolysis, you can test the coolant for it or have it done at a shop.
    – Derek
    Mar 21, 2018 at 22:48
  • What is the cause of the leak? Corrosion? Then internal (which will be coolant related) or external ( which means something has got on to it) or has it been punctured? Screw etc??
    Mar 22, 2018 at 13:16
Did you use the recommended coolant fluid? Did you mix coolants of different colors? Coolant formulations differ greatly.
The engine coolant fluid has to be changed periodically (usually, 2 years for the old green one and 5 years for the long life ones), otherwise its additives degrade and they no longer perform as they were originally meant to.
