I have an '04 1.2L 16v Renault Clio Dynamique with a leaking coolant flange/elbow where the lower coolant line connects to the water pump. You can see where flange is in relation to the pump and coolant lines here:
And you can see the obvious crack in the plastic flange here:
Can anyone help me source one of these things so that I can fit a replacement? I feel able to drain all the coolant and fit the thing, I just can't get my hands on one.
Thank you for your help!
Ari
