I am planning to write test specifications for verification, validation of power window switches:
  • driver side: auto up/down, manual up/down, door lock, window lock
  • passenger, rear right , rear left: window up/down switches
One low-end variant has anti-pinch for only driver side window, and the high-end variant has all doors with anti-pinch function.
The customer has various system requirements.
I would like to know test method, test setup to test the switches requirements in real car environment.
I am also interested in understanding various ways to break the system testing with negative test cases.
Let me know if any more information is required. I would gladly share it.
closed as off-topic by Zaid, MadMarky, Martin, Chenmunka, Nick Mar 14 '18 at 14:16
  • This question does not appear to be about motor vehicle maintenance or repair within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
  • Welcome to the site. I'm not sure if this question is within the site's scope – Zaid Mar 14 '18 at 13:22
  • 4
    I'm voting to close this question as off-topic because it might be a better fit on the QA.SE site – Zaid Mar 14 '18 at 13:24
  • There is a "flesh" standard which is just a polymer bar with a certain durometer which is used to test the "pinch" function. Obstensibly it simulates an infant's arm. Check the SAE J-spec database. – SteveRacer Mar 15 '18 at 3:38
  • Thanks Steve, can you please point out JXXXX code to find out which standard it is. – user3392184 Mar 15 '18 at 8:20
