[My 2003 Nissan Maxima, with standard transmission, is vibrating a lot.]
I have changed the motor mounts, ignition coil packs, clutch, and my car still vibrates. A lot.
Does anyone know what the cause is?
When I press the clutch at any speed I will feel the vibration, and when it is at idle it is more intense.
  • Welcome to Motor Vehicle Maintenance & Repair! Do the RPMs dip or fluctuate a lot at idle? – kyle_engineer Mar 8 '18 at 19:20
  • No, there is no dip in RMPs and no fluctuating at idle. It only has a vibration. The vibrate increases when I hold the clutch down , that is at high speeds (50-60 mph). Then the vibration is noticeable while at a complete stop. While accelerating there seems to be no vibration. Thank you. – RosaLinda Mar 10 '18 at 13:55
  • Does it seem like the vibration is coming from any place in particular? – kyle_engineer Mar 11 '18 at 22:16
