If anyone can help. I have error code P1700-TPS Circuit Malfunction-Check codes in TCM. Error Code P0731-Gear 1 Incorrect Ratio Error Code P0122 TPS Switch A Circuit-Low Input. I have asked this before. I do not have expertise to solve these. Does anyone know a great Subaru Mechanic that can solve this car and is it worth my time and money to fix. I don't mind driving to a place that I know it can get fixed correctly. Live in area code 15853 Thanks
  • what are some of the issues you are seeing with the car? sounds like shifting/driveability issues? – finleyarcher Mar 7 '18 at 21:25
  • Yes I have to manually shift if I am climbing a hill. Also will not accelerate as it should when pressing gas pedal – Forester Dave Mar 8 '18 at 1:08
  • Have you checked your transmission fluid levels? – finleyarcher Mar 8 '18 at 3:00
  • Yes But I will recheck this morning – Forester Dave Mar 8 '18 at 11:49
  • Did you ever adjust the tps with a multimeter? – Ben Mar 8 '18 at 12:33
