votes
Sidewall image
I accidentally hit the sidewall of the curb and it caused a small looking rip/tear. Do you think the tire is still good or should I replace it. I have a 4WD.
3 Answers 3
vote
I wouldn't worry about it, there's a lot of structural integrity baked into modern radial tires:
Radial Tire Cutaway
However, I would deem replacement mandatory if any of the following occur:
  • exposure of the radial plies (steel wireframe)
  • quick loss of tire pressure (5 psi within 2-3 days)
This link has detailed information on tire construction.
  • Following up on this answer: I'm looking at the picture and the scuffing on the tire is clearly moving diagonally across that crack in the rubber. I think that crack was likely present before the tire hit the curb.
    – Bob Cross
    Commented Feb 28, 2018 at 12:56
votes
Would you ever feel comfortable driving the car knowing that the tire is damaged like that? I certainly wouldn't.
The damage could be a lot worse inside. You also need to consider safety of other road users.
Replace the tire is the only advice anyone should give on here.
If you really need a second opinion, take it to a tire fitter and get their opinion.
votes
Replace the tyre as you can't see what damage has been done to the sidewalls structure. The sidewall not only supports the vehicles full weight but it is also subjected to all sorts of stresses and forces in all directions, as well as heat/cold/moisture & grit.
A sidewall split is an open wound for all these wearing elements and as its not repairable you only really have one safe option.
