I have a 1998 Honda Civic hatchback.
So this is my issue: I turned on my lights... my driver side works but my passenger light is out.
I hit switch for the high beam now the driver side headlight goes out (and is only the running light) but then the passenger side turns on and is a high beam.
I don't really know too much about cars and to be honest I haven't really looked. I was going to tomorrow. I just thought I'd get some opinions on what it could possibly be, so I have a plan of action for tomorrow and know what to look for.
7
Each bulb usually has 2 filaments in it, one for low beam and one for high beam. One possibility is that your driver's side bulb has a broken high beam filament and the passenger side has a broken low beam filament.
A search reveals that your headlight bulbs are likely of type H4 and look like the following. They match my description above. This video shows the replacement of one - https://www.youtube.com/watch?v=yqxOYVHAUQ8
If you swap the bulbs over, the described fault should move with the bulbs. If not, you have a different problem.
| improve this answer | |
