This is a 2011 Hyundai Sonata.
The car was running fine and I pulled into my friend's house and smelled something burning. I checked the oil and there was no oil so I put two quarts of oil and started driving.
It started making a ticking sound and shut off and will not turn on since. It will try turning over when jump-started but will not start.
    Did the oil fall straight out the bottom ? Sounds like the engine management computer has detected a significant problem and refuses to allow the car to start. Time to read the error codes. – Criggie Feb 21 '18 at 4:11
  • Where did the oil leak from? If there’s no leak that could mean your rings are bad and oil is getting into the cylinder, and being burnt – sjfklsdafjks Feb 22 '18 at 18:41
