25
I've bought a car which has ugly label glued to its rear window. What are inexpensive and effective ways to remove it without residue?
Edit: my car has it on the outside on the blank glass but it‘s good to know what to do when it is inside or on sensitive surfaces.
  • 7
    Inside or out? It matters
    – Chris H
    Feb 20, 2018 at 15:10
    Is there any sort of tinting or other cover that you are worried about protecting? Heat, razor blades, goof off (or similar), etc... whats best for a given situation matters mainly on what other parts you are trying to protect.
    – WernerCD
    Feb 20, 2018 at 15:28
    Get a sledgehammer. Smash the window. Call 1-800-autoglass. Feb 22, 2018 at 18:59
  • i always wd 40. you have to let it sit a bit, they also sell sticker remover spray as some jave stated.
    – Derek
    May 12, 2021 at 20:33
11 Answers 11
32
The most effective thing I've found for this is heat. Warm the sticker with a hair dryer. When it gets warmed to a certain point it will easily pull away without leaving residue. One word of caution though, when it comes off the glass completely it will try to stick itself to your hand. Hot plastic is not something you want on your hand, so wear gloves and have some water ready to cool the plastic or a sooth a burn.
24
On glass, heat would probably work well as mentioned, but I've worked at a car dealership for years, and always removed stickers and window paint with a simple straight razor blade and windex. The windex is really just for lubrication - spray a bunch around the sticker, and scrape it off using the razor blade at an angle. Any remaining residue can be cleaned up with more windex and fine steel wool (the finest you can find). Detailer's trick ;)
enter image description hereenter image description here
Word of caution however, DO NOT DO THIS if it is on the inside of the rear window and you have defrost lines, OR if you have aftermarket tinted windows, as razor blades and steel wool can easily ruin both.
If either of these are the case, you are in for a bit more of a hassle, and I would suggest just sticking with just heat and windex or some sort of goof-off and a rag to work at it.
  • 11
    I really don't like the idea of people putting steel wool to their cars. Feb 20, 2018 at 20:23
    @LateralTerminal Sounds crazy, doesn't it? I was a bit surprised the first time I saw it being used as well, but it actually does wonders! Just make sure it's the finest steel wool (0000), not rusty, and you're working on plain glass (definitely don't do on paint!) Check this or this out for example.
    – sǝɯɐſ
    Feb 20, 2018 at 22:17
  • 5
    @LateralTerminal, glass has a significantly higher scratch hardness than steel wool. If the windshield weren't so incredibly smooth, it's the steel that would be damaged by this process.
    – Mark
    Feb 21, 2018 at 3:13
    @sǝɯɐſ And not contaminated with grit. Feb 21, 2018 at 22:57
  • FWIW, there are "before-market" treated windows, too. My car has some (albeit very hard) UV-block coating on the outside of the windshield. So yeah, be careful Feb 22, 2018 at 19:00
12
Acetone and isopropyl rubbing alcohol (90% and higher) are very effective at dissolving glue without affecting glass. It will affect any other plastic layer on the window so you should check for any anti-UV screen or other.
I suggest a combination of Steve Matthews' answer (remove the plastic with heat) and afterwards get the eventual glue residue off with Acetone and a rag.
Beware Acetone is a dangerous chemical : wear appropriate PSE (googles, gloves).
    could this damage the car paint?
    – Kinaeh
    Feb 20, 2018 at 13:43
    @Kinaeh, Acetone typically will not damage car paint if you spill a little, but it is better known as "finger nail polish remover", so some finishes will be damaged. For good car paint, worst case is probably going to be stripping the wax in the area of the spill.
    – JPhi1618
    Feb 20, 2018 at 15:38
  • It's bad if you don't wipe it off right away and if you do it a lot Feb 21, 2018 at 14:15
    I wouldn't bring acetone anywhere near a car. There are so many things it can damage if you spill it - the glass (on the outside) is fine, but just about anything else will have a bad news reaction.
    – J...
    Feb 21, 2018 at 14:24
  • @Kinaeh if you take an old rolled up towel (shirt, rag, etc) and put it at the bottom of the window before any painted surfaces you should be fine. Acetone evaporates rather quickly, so the rolled up cloth is basically just a buffer to stop the acetone from reaching the paint until it evaporates out.
    – Doktor J
    Feb 22, 2018 at 16:11
Sticker remover or sticker adhesive sprays and manual scraping work a treat.
I'd use a plastic scraper or credit card to avoid damaging rear defroster lines.
Turtle Wax
  • I don't suppose Turtle Corp lists the ingredients? Feb 22, 2018 at 19:01
    @CarlWitthoft Here's a data sheet
    – Zaid
    Feb 22, 2018 at 19:04
  • ok, so ether, acetone,and gasoline, basically Feb 22, 2018 at 20:00
For anything that's just glass, I would follow @James' answer regarding a razor blade and any glass cleaner; it's definitely the best tactic.
For the inside of the rear window where you have the defroster lines running, I've had the best luck with the aerosol "professional strength" version of Goof Off (or likely any other xylene/heavy solvent based cleaner). I used this along with a liberal amount of shop towels to remove the entirety of the old cheap rear tint residue on my rear windshield.
Heat is the first answer, but I've found that even with heat, I've had residue left over. Goof Off didn't attack the defroster lines, but worked wonders against the leftover adhesive residue.
Goof Off Aerosol
Naphtha, available at any hardware store in the paint section, works beautifully to remove sticker residue. It is commonly used in furniture refinishing and luthiery for applications similar to that described.
It will dissolve and lift any sticker adhesive I've encountered off glass, metal, plastic, ceramic, and even lacquer without damage to the underlying finish. It won't dissolve plastic like acetone, and doesn't require any razor blades or scouring. Just saturate the sticker with naphtha, and then wipe away the residue with a shop towel.
It also works quickly on those very difficult-to-remove notices placed on your window after your car is booted or towed, again with no knife or steel wool required.
Stickers are constructed of a huge variety of adhesive - some with a greater affinity for the glass, some with a tendency to stay on the underside of the sticker. The first step should always be to lift a corner (with thumbnail or properly mounted safety razor), grip the corner and pull; begin with a slow pull and note which surface the adhesive is sticking to. If it is sticking to the underside of the sticker, it will avoid having to follow-up with a solvent to remove it from the glass. If the slow pull leaves the adhesive on the glass, try pulling more quickly; the adhesive may then stay on the sticker. However, a faster pull may tend to tear or shred the sticker, complicating the removal. Occasionally, razoring the line of detachment as it progresses can be the best approach. Caution: Razors can inflict very serious wounds!
The glue from stickers of most kinds is easily removed with WD40, the same stuff used to stop squeaks and lubricate things.
It will mess up the finish on wooden furniture, so this is not a general solution, but perfect for glass or metal, like OP's issue or when a used computer has a sticker from the reseller.
There is a citrus based cleaner called GooGone that also works great for removing many adhesives. And it smells nice when you're done. I use it frequently to remove price tag sticker residue after removing as much of the sticker first by peeling or scraping. A google search shows that a lot of places carry it.
A straight razor blade, Goo Gone, and warm soapy water. Works like a charm.
  1. Using the blade, gently scrape away the sticker material.
  2. Use Goo Gone according to the directions to remove any residue.
  3. Wash away any leftover Goo Gone with warm soapy water.
Edit 1: Hopefully it goes without saying, but this works on glass only. Don't try it with painted surfaces.
Peanut Butter
  1. peel off sticker's plastic coating, if there is one
  2. smear some peanut butter over the sticker, leave it until the sticker gets soft and comes up easily. 20min - 3hrs
  3. wipe it off, the sticker and glue should come off easily. clean residue with soap and water
Why does this work? Oil breaks down that kind of sticker glue. But if you rubbed oil on it it would run down the windshield, and not sit there long enough to work. The peanut butter stays put, allowing its oils to work.
