Engine fires, idles rough shuts off. No codes. Unable to find vehicle service manual online. Unsure if Chilton's covers the removal/replacement procedures for sensors as I will be shotgunning this repair starting with the least expensive parts, TPS throttle position sensor, then O2 sensors, then ECT sensor then VAFM then ECU then wires.
As I have no information as to the testing of each of the sensors. All information I have gained is from online forums and there are many different pinouts and testing ranges given that are contradictory.
It will cost us $300.00 to tow it. And I would like to spend that on fixing it instead. It has run flawlessly until this and has had the best maintenance record possible over an inch thick of receipts.
