Vehicle will not start. I have replaced the CKPS sensor with a used one, but it still brings back the code P0335. before I shell out cash for a brand new sensor. Am I on the right path?
Here are my test results:
Power supply meets specification: B+
CKPS Power meets specification: 4.98V
Signal Circuit check for short to ground in harness: DMM reads 0.25 ohms
Signal Circuit check for short to battery harness: DMM reads 0.45 ohm
Signal Circuit check for open in harness: DMM reads between 0.1 ohms and 0.2 ohms and makes the continuity sound
Ground Circuit Inspection : DMM reads 0.1 ohms and makes the continuity sound
I doubt that I have a bad Crankshaft Position Sensor (Crank Angle Sensor)? I also doubt that the PCM is bad. What is the best way to hunt down and eliminate these shorts without tearing out the wiring.
