With some internet searches, is seems like the 2012 Ford Escape requires the MERCON LV Automatic Transmission Fluid
, but I haven't found an official source to confirm that. Can anyone provide an official source that says that is or is not correct?
1 Answer
According to page 325 of the Owner's Manual, it uses Mercon LV ATF or equivalent.
I know this to be true because I have an Escape also.
1Also noticed that the dip stick has a label that says to use MERCON LV fluid Mar 7, 2018 at 17:21
