This question already has an answer here:
My car is running on pure distilled water in its radiator.
No winter here, so freezing the coolant wouldn't be a problem.
It is running on pure water because I'm the 2nd owner and by the time I bought it, it is already the case.
I planned on replacing it with the pre-mixed (ready to use) coolant but one of the mechanics advise not to and just leave it be if I have no problems (and actually I have no problem, haven't had any overheating issue since I bought it). He said that sometimes, new coolants doesn't help on old radiators since is shortens its life more. I got curious and search but have not seen any documentation about it.
Will it really hurt the radiator if I put coolant on it now?
marked as duplicate by Pᴀᴜʟsᴛᴇʀ2 Feb 11 '18 at 13:13
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • It might be useful to know the vehicle's model and year of manufacture – Zaid Feb 11 '18 at 6:58
  • What is the highest temperature you are likely to see? – mikes Feb 11 '18 at 12:12
  • Coolant prevents galvanic corrosion, water encourages it. Water is better in transporting heat, which is why it's used in combination with coolant. The life of a radiator is certainly not shortened by coolant. You can use water in an emergency, but change to coolant once you get the opportunity. – Bart Feb 11 '18 at 15:49
  • @Zaid Mazda 323f 2000 AT. – L42 Feb 12 '18 at 5:15
  • @mikes highest is just below mid range. Not sure of the exact temperature, gauge is not digital. – L42 Feb 12 '18 at 5:18
This will depend on the car as usually now the metals used in the engine block, head and radiator with the presence of electricity can cause electrolysis ie one of the components gets “eaten”.
This is why the correct coolant type should be used - some have inhibitors designed for aluminium etc.
  • Yeah exactly what I was looking for. Are there guide like what type (brand) of coolant to be used in specific model / make of car? Or specific alloy used in radiators? – L42 Feb 12 '18 at 5:14
  • It is not the brand you should look for as most brands will sell several types of coolant inhibitor : you need to check the specs and get the correct one. Either your car manual will tell you or the dealer can or a decent store will have the charts where you look up your make and model... – Solar Mike Feb 12 '18 at 5:17
  • Ok, so I will have to look for that before I flush and refill with coolant. Btw, I was surprise why this was marked duplicate. I think we have to be aware that although using coolant is way better, we have to choose the correct one. – L42 Feb 12 '18 at 5:21
  • And, you cannot mix them - adding an incorrect inhibitor to the correct one will cause problems. – Solar Mike Feb 12 '18 at 5:23
