1971 Galaxie 351W with AOD converted to injection with GT40 lower + upper intake and SVO controller F3ZF-12A650-FB from 1993 in set-up with software C3W1 :
  • Injector size 19 pounds or 24 or even 32 pounds ?
  • MAF 70mm or 80mm ?
Both must work with the Ford-SVO controller, the installed C3W1 software was written to smooth and precise match the inlets and outlets of the electronic system to provide a optimised motor operation. But nobody can tell me the factory-SVO system set-up, nor I was able to retrieve factory information.
  • Welcome to Motor Vehicle Maintenance & Repair! Can you specify the exact information you're asking about? Reading your question leaves me a little less than understanding what you're looking for. – Pᴀᴜʟsᴛᴇʀ2 Feb 10 '18 at 0:50
  • So, first question - what vehicle had the “standard” svo setup as originally supplied by Ford? – Solar Mike Feb 10 '18 at 5:43
  • @SolarMike F3ZF-12A650-FB C3W1 should be for a 5.0 Mustang GT with an automatic. In which case F1ZZ 12B579 AARM should be the MAF and F1ZZ 9F593 C should be the injector. – Ben Feb 10 '18 at 15:08
