I tried to start my car today but I didn't want to start, last time I drove it it worked fine. The video at the bottom shows how it sounds at startup.
-3/-4 degrees celsius at the time this happened.
Sign up to join this communityI tried to start my car today but I didn't want to start, last time I drove it it worked fine. The video at the bottom shows how it sounds at startup.
That sounds like the battery not having enough juice to turn it over. At -3/-4C it's not that cold (just below freezing). Isn't going to hurt it much, but it does cause greater stress on the battery to try and start the vehicle.
Check the voltage at the battery. I'll bet you'll find it down around 10-11vdc. You may want to take it in to a parts store and get it load tested. Also check to ensure the posts are completely clean of corrosion. If they are corroded, clean them off, then put a battery charger on the battery, then try it again. If the battery is over five years old, it's probably time for a replacement anyway.
