I've got a problem with a 2013 Ford Fiesta's climate control. The choices between the system are you freeze or roast.
The system is the standard Ford one - options: "Lo" - 15.5-29.5 celsius - "Hi".
There's nothing coming up under diagnostic codes and I've had a friend check the pumps, refrigerant etc. but as he's a mobile guy there's a limit to how much he can diagnose without taking it apart.
The problem is - that under "Lo" it comes out at 8°C from the Air-Con - which is as expected. Everything from 15.5 up to "Hi" comes out as 35°C and when set to automatic, it never turns itself off.
I'm assuming there's a faulty sensor somewhere in the car - is this something that can be resolved with a bit of DIY or would this need to be resolved by a professional garage?
    Welcome to the site. Has it worked properly until recently? Was there a specific event when it started happening? Does it work as it should if you adjust it manually?
    – CharlieRB
    Feb 7, 2018 at 18:10
  • To calirfy, codes in the HVAC module or in the PCM?
    – Ben
    Feb 8, 2018 at 0:40
