OK - this is frustrating. It was dead simple to read the error code on my old 323i using the button on the stalk.
I recently bought a 2014 328i xDrive and for the life of me cannot find a way to show the error code using the iDrive system or some other means.
My engine light came on yesterday. Normally I would just plug in my OBD reader, but I seem to have bricked it with the vendors last firmware update.
Surely there's a way through some menu item to get the CC-ID code that is causing the fault.
Thanks.
  • Welcome to Motor Vehicle Maintenance & Repair! Feb 6, 2018 at 1:45
You won't be able to view fault codes through the iDrive interface.
Sadly, an OBD-II reader is the way to go here.
  • Good thing they're pretty cheap and easily available, still it's annoying they took a useful feature away.
    – GdD
    Feb 6, 2018 at 9:29
