I run my car in normal use in highway and no traffic I spend $20 full tank 90 miles I replace my tires,spark plugs Oem ,Transmission fluid with filter,Engine oil with filter,Thermostat,antifreeze,Air filter,replace the Ignition Coils and no codes are present I just need some good person out there that can give a good advise on this issue what will be the next procedure to correct this dilemma for this issue started a month ago and Thanks.
Welcome to Motor Vehicle Maintenance & Repair!– Pᴀᴜʟsᴛᴇʀ2 ♦Feb 5, 2018 at 15:37
Have you had the vehicle checked for fuel leaks? Do you ever smell gas when you get out after driving it?– finleyarcherFeb 5, 2018 at 21:25
No fuel leaks so far and I already check the front lines to the injectors and from the gas tank too.– KiroFeb 6, 2018 at 0:10
no gas smell at all?– agent provocateurFeb 6, 2018 at 19:04
Please provide fuel economy numbers before and after. Knowing the difference will assist with narrowing down what it could be.– iDriveSidewayzMar 14, 2018 at 11:56
1 Answer
Have you checked your intake valves? its a longshot but maybe
My car have 127,000 miles on it and I always use Shell gas 91 octane and I don't think my intake valves are bad and thanks for the thought– KiroFeb 7, 2018 at 14:12
