is there a special hidden reset switch or button in a 2001 bmw 323i to get the car to turn over and start after having the negative cable disconnected then reconnected? The most it does is 3 clicks everytime.
  • Why did you disconnect the battery? What else was wrong? – JPhi1618 Feb 2 '18 at 19:16
  • The battery is healthy and charged? – Solar Mike Feb 2 '18 at 19:39
I had a 2003 325i and disconnected the battery many times with no issues afterwards, make sure the battery is charged and connections are clean and tight.
