I'm having a strange issue with my 1999 Accord. It's an intermittent issue where it will crank but not start. The issue seems to happen most often when you take a short trip followed by a short stop, then try to start it up again. If you then let it sit for five minutes after the failed start attempt, it will start fine.
Edit:
CEL is not on.
Edit 2:
Was talking to a guy a few days ago and said it might be a particular part, I believe he called it the "main relay" but can't remember for sure. He said that I should listen for a click under the dash as I try to start it. If it makes a click when it starts, but not when it won't, then it was this part that was going bad. It refused to start today for the first time since that conversation, and sure enough, no click. Can anybody confirm that a) I'm remembering correctly and b) that this diagnosis makes sense.
