I'm Bram from the Netherlands. At home we have an 1959 Chevy El Camino. When we have the headlights on after a couple of minutes. The lights begin to turn off couple of minutes later on, and like that the whole time.
Any of you know What this could be? I'm a mechanic myself at the Dodge dealer.
Greatings Bram Hofs
  • Welcome to Motor Vehicle Maintenance & Repair! Is this an import from the States? Meaning, is the El Camino a US spec'd vehicle? What engine does it have in it? Do you know if it has an alternator or a generator (not sure when GM switched to alternators)? – Pᴀᴜʟsᴛᴇʀ2 Jan 25 '18 at 21:14
  • Probably start by doing voltage drop testing on the headlight wiring and watching it until the light shuts off. – Ben Jan 25 '18 at 22:52
  • Is this one of the vehicles that had a « re-setting » breaker instead of a fuse for the headlights? If so, there may be a short-circuit or has someone « upgraded » the bulbs causing it to be overloaded? – Solar Mike Jan 26 '18 at 5:40
  • I second SolarMike, my '76 TR7 also uses it in the headlight circuit, and in the manual, it's called a 'circuit breaker'. You may look for that term in your manual. It's just a self resetting fuse that disables when the current exceeds a certain threshold, only to re-enable after either some time, or after the electrical load has been removed. A wrong type may have been fitted, or it may have broken down partially due to age. – Bart Jan 26 '18 at 11:01
