I have a new Toyota Camry 2017 which features a HomeLink garage door opener. I have a garage from LiftMaster (I don't know any details because I did not buy and/or install it). The remote looks like:
I followed the procedure in the manual exactly and everything happens as stated in the manual:
The HomeLink(R) compatible receiver in your vehicle has 3 buttons which can be programmed to operate 3 different devices. Refer to the programming method below appropriate for the device. Programming the HomeLink(R):
- Point the remote control transmitter for the device 1 to 3 in. from the HomeLink(R) control buttons. Done.
- Press and hold one of the HomeLink(R) buttons and the transmitter button. Done. When the HomeLink(R) indicator light changes from a slow to a rapid flash, you can release both buttons. This happens after a couple of seconds and I release the buttons
- Test the HomeLink(R) operation by pressing the newly programmed button. If a HomeLink(R) button has been programmed for a garage door, check to see if the garage door opens or closes.. It does not.
I found Youtube videos which connect the same LiftMaster remote which their car so I am sure it's HomeLink compatible (also the fact that it programs successfully).
What could be the problem?
For reference, this is the garage door:
