I recently purchased a GTI mk4 and it needs a little fixing up but it runs great.
However, I would like to clean up duct tape residue but could possibly be other things as well from the interior of the car. (Please view attached picture).
I appreciate your help!
Thanks.
1Idk where you live but there’s this stuff called goo-gone try that maybe if nobody else has ideas– sjfklsdafjksJan 16, 2018 at 22:25
That's going to be tough, because a lot of the things I could think to try would probably also warp and damage the plastic of the dash. +1 and hoping someone has some input.– JPhi1618Jan 16, 2018 at 22:33
Thanks. @JPhi1618 for the reply. I’m in Los Angeles. I just picked up some isopropyl 91% hoping it will work. I’ll try it out first in a place that you can’t really see. If it doesn’t clean it or it does but ruins the dash, do you know of ways to cover the dash?– GtiOwnerJan 16, 2018 at 23:04
I have used WD40 in the past - it does not tend to damage the plastic...– Solar MikeJan 16, 2018 at 23:20
that looks to me like a big crack in the dash that was taped over.– agentpJan 17, 2018 at 2:58
