I recently bought a Nissan Caravan (year 2000) and I still don't know the function of two switches. Unfortunately I don't have a manual and I couldn't find information on Google. Maybe someone knows what the switches/knobs shown in the pictures are for? Thanks, Stefan enter image description hereenter image description here
  • Welcome to Motor Vehicle Maintenance & Repair! Jan 9, 2018 at 1:51
    The second one looks like for an interior light. The first one, no clue. Jan 9, 2018 at 1:56
  • First one is most likely after market. And the second probably fog or interior lights.
    – Granny
    Jan 9, 2018 at 12:03
  • Is this van equipped with a diesel engine? Have you attempted to use the switch? Does anything happen or any lights on the dash illuminate?
    – CharlieRB
    Jan 9, 2018 at 14:00
  • Yes. It's a 3.2l diesel engine. And it's a 4x4. I tried to use the switch but nothing happens. I realized that the internal lights . I'll replace the lamp asap and try again.. Jan 10, 2018 at 5:15
The first looks like a valet or kill switch for an after market alarm system. Look for a black box under the dash somewhere or a non oem led indicating alarm.
The second is, based on the logo. For internal lights or fog lights. It could be wired to something else completely and unless it's fairly obvious when you flip it, you would have to trace the wire out. Based on the screw hole right below it, that car was obviously nodded without a delicate touch.
  • Thanks for the answer. Good point. Never thought about subsequent modifications. :) Jan 10, 2018 at 5:22
  • The first is throttle idle control for diesel. Turning the switch clock wise makes idle faster or vice versa.
  • The second one is the interior light master switch.
